Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé en mars 2017, le Moto G5 Plus (numéros de modèle XT1687, XT1680, XT1684, XT1685) inclut une caméra arrière de 12,0 mégapixels, un écran tactile de 5,2 pouces avec une résolution de 1920 sur 1080 pixels ainsi que le système d'exploitation Android 7.0 (Nougat).
Why does screen stay black when calls come in?
I am the original and sole owner of a Motorola G5 plus 64gb running Android 8 1. After my first year of ownership (approximately) I started to notice that my screen would stay black when I was receiving an incoming call. Nothing I tried could wake the screen: I tried pressing the power button on side and also touching the thumb pad /finger print sensor but nothing worked. But after I missed the call the screen would wake to tell me so (ie that I missed a call…thanks a lot). Here's the even more bizarre thing…it only happens about 50% of the time (approx.). It's really frustrating because I have to wait till I miss the call to find out who was calling me so I could then call them back.
Help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
it has to do with the proximity sensor, usually when you have flip to mute enabled in the my moto menu/app it shuts off the display in order to save power and mutes the incoming call.
this can occur if the adhesive around the proximity sensor loosen and form a gap between it and the glass or ge debris or residue get on the inside or outside of the glass.
the solution i have found, although a bit barbaric is to apply pressure AROUND the proximity sensor and whilst doing so taking the call.
if this doesn’t help wiring a headset and taking the call with the remote is an option
Indice 3
1 commentaire:
the earphone trick works
par
Hi,
Strange that it only occurs 50% of the time.
Try the following to see if it resolves the problem or at least narrows down the cause of the problem further.
Being intermittent you may have to leave it for a while after doing each of these procedures until you know one way or the other whether it still happens.
Wipe the cache partition and then check if the problem still occurs.
If still occurring, start the phone in safe mode and check if the problem still occurs.
if it doesn’t happen when in safe mode, then a downloaded app is the cause of the problem. You will have to uninstall each downloaded app, one at a time and check the phone in normal mode between each uninstall, to see if the problem is still there or not. When the problem no longer exists then the last downloaded app that was uninstalled is the culprit. A downloaded app is one that you downloaded and installed and wasn’t pre-installed on the phone when you first got it.
Indice 1
6 commentaires:
Jayeff, my thanks for the suggestions. I’ll give this a try over the weekend (I’m in the middle of a very busy week) and will report back over the next week to give you appropriate and, more importantly, accurate feedback. Thanks again. Mark
par
I have the same problem screen goes black on incoming calls and you can't pick up the call
par
Same with me. And it is only 50% of the time also.
par
Yes this happens to me when phone in my pocket and take out to answer always have to person back
par
Same problem with my phone. I looked at the two responses to deal with this but unfortunately I don't know where the proximity sensor is or how to wipe the cache partition.
par
Afficher 1 commentaire en plus
Ajouter une réponse
Mark DiRollo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 126
Total : 19,302
