Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une version plus abordable et purement portable de la console de jeu Nintendo Switch, avec des manettes Joy-Con intégrées et un écran légèrement plus petit. Sortie le 20 septembre 2019.
Replaced left joystick and now screen doesn't work
I dropped my Switch Lite and the left joystick snapped off.
I was able to connect a Pro Controller until the replacement joysticks came in so I know the unit was working. Bought a 2 pack of replacement sticks. Neither replacement worked and now my screen doesn’t work.
Unit has power. Sound works for all of the buttons & the right stick. Even the left stick makes the boing sound when pushed in but not other sounds up/down, left/right. I only removed the daughter board when replacing the left joystick so I can’t see where/how I could have unplugged the screen.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
4 Réponses
Réponse la plus utile
The screen ribbon cable connects to the daughter board right next to the power button ribbon cable. Make sure it’s properly seated and also inspect for damage.
Indice 1
How is it now? Is it fixed?
Indice 0
I have this problem too, tried reseating the ribbon cable a couple times but no luck what do I do?
Indice 0
I had this issue as well a couple of years ago with my Switch Lite and I got it working by taking a Q-tip and isopropyl alcohol cleaning the LCD cable to the best of my ability then making sure it was seated properly. what caused it not to work for me was that I had gotten a little bit of thermal paste on the LCD cable that i didn't notice and cleaning it helped so maybe you can give that a try.
Indice 0
Ajouter une réponse
kai mpqii sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 36
Total : 3,408
