Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Galaxy Watch Active2 est une montre connectée de Samsung Electronics. Son numéro de modèle est SM-R825, SM-R830 ou SM-R835 et elle a été commercialisée en août 2019. Réparer votre Samsung Galaxy Watch Active2 avec ces tutoriels.
My touch screen doesn't seem to be working on my Samsung Active2 watch
The screen on my watch doesn’t seem to be working. I can’t get into any of the widgets. It doesn’t seem to be “feeling” my taps. Is this repairable?
Répondre à cette question J'ai le même problème
Indice 10
2 commentaires
Software update...us
But not working my whatch
par Partager
60 dayes no work display
par Partager
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Hi gary & chris,
you might want to check if the display connector sits properly on the motherboard or see if there is any dirt or remnants of water inside the watch which may affect the touch function of the display.
See this back cover guide to get inside. The top connector in the last image is the display.
Also you can read this thread (Samsung forum) on water damage on Galaxy watches for more background information.
If still under warranty from Samsung you may be eligible for a replacement or repair.
Remplacement de la coque arrière de la Samsung Galaxy Watch Active2
Indice 2
1 commentaire:
Bought a decent Y00 as didnt have one, but %#*@ screws were in so tight i ended stripping the heads trying to get them out.
par Partager
Along with this issue a few users are facing issue with their watch that it keeps responding without any touch. So, here are a few methods to fix the watch facing Ghost Touch issue.
Indice 1
2 commentaires:
Actually from the searching around I did. I found out that repeated sloppy water exposure were the common tigger for ghost touch. The glue on the active 2 isn’t the best, some watch even open by themselves because of heat and normal use. Soppy water seems to more easy get to and damage the screen digitizer. If you wear a case over the watch it kill it faster because the humidity is getting trap and end up going insides the watch.
par Partager
Can this be fixed? I noticed it started after high humidity and having a screen protector over it
par Partager
From the « research » I did (basically I read through a lot of other people that the issue wasn’t fixable by software). I found out that repeated sloppy water exposure were the common tigger for ghost touch. The glue on the active 2 isn’t the best, some watch even open by themselves because of heat and normal use. Soppy water seems to more easy get to and damage the screen digitizer. If you wear a case over the watch it kill it faster because the humidity is getting trap and end up going insides the watch
Indice 0
1 commentaire:
I think you are also right men
par Partager
Try knocking the watch. I think it will help the watch display connector back in place.
Indice 0
Ajouter une réponse
gary & chris vance sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 23
30 derniers jours : 85
Total : 20,593
