Aller au contenu principal
{A1989 / EMC3214} — Sorti en juillet 2018, le MacBook Pro 13" contient des processeurs quad-core i5 et i7 et une carte graphique intégrée Intel Iris Plus.
204 questions Voir tout
doesn't power up nor can it charge
my 2018 13 inch Retina display MacBookPro doesn’t power up and doesn’t charge. I tried SMC reset as well as as PrAM/NVrAM reset but they all failed to power up. is there another fix I can try before I bring it to a fixit shop?
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
Does your charger have a LED on it when plugged in? If so what the colour of the LED. If not, possible the IO Logic Board (The smaller separate logic board) has damage or even a main logic board issue. It could also be a bad battery, which would be the better issue to have.
par
@eazy_pc_repairs - Jon - This series uses a USB-C charger which doesn't offer a charging LED. Really need a USB-C power meter to give you the info on your charger and battery.
par
@danj Sorry about that, I did not think :D Voltmeters are relatively inexpensive (£20 or so) though so OP you should be able to get one quick enough and let us know your findings, Amps draw will tell us a lot about whether its dead or trying to turn on or partly booting :)
Let us know if you decide to get one and let us know. I know my amp lighting cable for iPhones is a huge help :)
Good luck Sir
par
Ajouter un commentaire
3 Réponses
When I first got my second hand Macbook it came with a charger that didn’t have enough voltage to charge it - the cable was connected to an iPad adapter. It went super dead and couldn’t power up or seemingly charge. Make sure it is the correct charging block? The 61W one I think.
Indice 0
Is there a chance that you can open and try to reconnect the battery connector, because i had a same peoblem before the battery is totally drain and it pwont charge, so i tried to reset battery connector then it work.
Indice 0
1 commentaire:
I have reset the battery about 10 times now nothing when I put the usb type c multimeter on it it says it’s getting 20V but I’m only getting 0.989A to charging. When I first installed the new logic board I got the chime that the charger was connected but when I put it to DFU mode tried to revive the Mac the restore I don’t get that now but it never turned on
par
i think your peocess of dfu is unsuccessful , just try this link.https://support.apple.com/en-ca/guide/ap...
Indice 0
1 commentaire:
Yeah that’s guide I went by was no help
par
Ajouter une réponse
Tony Bosco sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 149
