How to install speakers for it into this laptop. Headphones work fine
I am a longtime mac user with 3rd party speakers for this machine on hand but am not overly techy myself . Should I try it or know anybody who can install this in the Princeton area?
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
To be clear you have the correct speakers for your system not just any speaker - Correct?
MacBook Pro 13" Retina (Late 2013-Early 2015) Left Speaker
MacBook Pro 13" Retina (Late 2013-Early 2015) Right Speaker
As long as they are designed for your system you should be able to replace your current ones if that is the problem. But let's make sure!
When you use the headphones or external wired speakers the sound is fine.
When you unplug the headphones/speakers the sound stops or is garbled?
par
Yes, the correct speakers left and right I bought online. And while I don't know about externally plugged in speakers, I do know that headphones deliver perfect sound and when unplugged, they are terrible [both sides] using the speakers that are in there now. I hope that tells you enough!
par
Good! So the issue is not the headphone jack, if you didn't get any sound then that imply the jack was bad.
par
Ajouter un commentaire
