The touchscreen do not have ligth and battery do not charge.
The screen show information but whitout light, and the smarthphone do not charge the batery, I quited the screen and put other but the problem persist, I buy a new batery and it do not charge too. this 2 problem appear at the same time.
2 commentaires
I detach all parts of the PALM, I check the battery conector, but the problem yet exist. I think there are a circuit short, because when i put a good battery the palm is ok but without light, though the battery discharge in a few minutes. Probably changing de logical circuit the palm work again so Í´d like to know if there are a Logical Circuit so i replace it from my palm,
thank you so much.
par Jorge
Does it charger from the USB port? Doe sit do anything when you plug it is? Any change in the battery indicator? Any recent software updates? Did anything happen to the phone? Did it get dropped, any water issues? Check both ends of the cord, as well as the charging port on the phone, for corroded or broken pins. Clean the port with isopropyl alcohol to remove dirt and debris. If you are charging it with the power cord, use the USB cord, or the other way around. Depends on how you charge. Let us know what you have tried and what the results are. Good Luck.
par oldturkey03
