It is always helpful to explain clearly exactly what you actually did and how you did it.
For example, were you trying to install Linux from within Windows???
Did you back up your data files, etc.?
Do you want to get Windows running again? If so the first thing you can try is booting into the Windows recovery environment, if possible, and then performing a start-up repair. To access the recovery environment, turn your computer on and off three times. While booting, make sure you turn off the computer when you see the Windows logo. After the third time, Windows 10 will boot into diagnostics mode. Click Advanced options when the recovery screen appears.
Click Troubleshoot.
Click Advanced options.
Then, click Start-up Repair
If this is not the case then just make a Kali Linux bootable USB drive and do a clean install of Linux.
Here is a link to the manual for the Gateway series. It may help you:
https://global-download.gateway.com/GDFi...
On the underside there may be a battery reset hole on the underside. see page 13. Unplug the charger and press a paper clip through the hole. Now try turning on the computer. Anything? Do LED’s come on or anything on the screen?
Have you tried pressing F2 key while powering up?
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires
What operating system was on it before you tried to change?
par mike
From windows 10 to Kali Linux
par Aditya B R
I not seeing anything on my laptop
par Aditya B R
