iPhone X 4013 error does not enter dfu mode
Hey guys, got an iPhone X water damaged with 4013 error, ruled out common issues like the speaker flex and changed housing too. Same issue occurs. Phone doesn’t enter DFU mode, and gives me 4013 error on iTunes. I am suspecting a bad NAND Flash chip so i wanted to know how do I remove the nand? As I’ve never done a NAND fix on a Sandwich Layer Board. Do I seperate the two halves or straight away remove the chip? Because i’ve seen people where they do not seperate the board halves and remove the nand flash. Also if there could be any other issue someone can point me towards would be helpful.
2 commentaires
Also it was previously repaired by another tech and it was working fine, then suddenly the Taptic Engine stopped working so i suspected it was a bad charging dock so i tried a new one too, and new housing aswell, Same issue. User told me he was updating it and left it at that, when he came back it was bootlooping.
par Myron.
Uploaded the iTunes Restore Logs here:
https://hastebin.com/ibuyokizad.yaml
par Myron.
