Aller au contenu principal
Repair guides and support for your Philips TV.
Questions au sujet de 155 Voir tout
Black screen with audio and ambilight working
Hello I have A 55PUS6501/12 that has black screen . I have tested with A flaschlight and dint se anything. I have cheked 1 fuse on the mainboard and one on the t-con and they are working. I have about 60 v out on the led on the main board. T-con have 12 v . And sugestion what to do ? Thanks// Robin
Update (07/29/2021)
The w red cables are get 60v each.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Solution retenue
@normansweden 60V on the backlight LED is not enough. Double check your power board and see what voltages you get on the connections to the main board. It is the main board that tells the power board to turn on. If the voltage on the backlight LED connector is/stays at 60V you are having a power issue on that board. Check for more fuses on it. Post some good pictures of your boards with your question so that we can see what you see. Ajout d'images à une question existante
Cette réponse a-t-elle été utile ?
Indice 2
Ajouter une réponse
Robin Norman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 28
