Aller au contenu principal
Sorti le 16 septembre 2016, modèle 1778, 1784. Disponible en version 32, 128 ou 256 Go en or rose, or, argent, noir, noir jais et rouge.
Questions au sujet de 1218 Voir tout
iPhone 7 Plus Logic Board Repair
In the process of replacing the Baseband Power IC on the iPhone 7 Plus’ logic board (an attempt to resolve the phone being unable to activate) and reballing its base, I’ve accidentally dislocated and removed 7 adjacent capacitors as well as a smaller chip to the right (viewed from the orientation of the photo), in addition to the Baseband to the left being damaged/unaccounted for.
How would I go about replacing all of this? Are these capacitors (and their sides) identical, and what’s the likelihood of the phone being rendered unusable even after they’re replaced? Would help if there’s a detailed diagram of parts on the logic board (inc. names of all parts) available.
Thanks for any help.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 solutions
Réponse la plus utile
There is schematics and board view software for that model of phone, they will display the components and there values. However since this is the Qualcomm board and not the intel the unable to activate message will more than likely be a shorted baseband CPU it is a signature fault on this phone.
Apple even had a replacement program for this fault but it is no longer continued. The baseband CPU is not replaceable as it is linked to the CPU.
Cette réponse a-t-elle été utile ?
Indice 1
Seems like you knocked off some important baseband related caps, you need to install them and also you knocked off the homer ic which controls vibration. You need to reball that and fix that too. Hope this helps :D
Indice 0
Ajouter une réponse
Mars sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 25
