Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Réveil simulateur d'aube colorée Philips, avec 5 sons naturels et radio. Sorti en avril 2017. Numéro de modèle : HF3520/60.
Light doesn't stay on when clock reaches actual alarm time
My clock has an issue where the light comes on during the build-up to the alarm, but turns off once the clock hits the actual alarm time (but demo mode works perfectly). It usually would keep the light on for about 90 minutes after the alarm time unless turned off, but it stays off during this time as well. What’s strange is that the clock display is brighter, like the clock knows the alarm is happening, but the actual wake-up light is not on. Sometimes, unplugging the clock for a few minutes and plugging back in can fix this for a few days, but other times that doesn’t work. It’s very frustrating and has made the alarm completely unreliable.
Also, occasionally I get the random clicking sound like it thinks the buttons are being pressed when they’re not, as mentioned in a question by another user. I’m not sure if these are related or not.
As stated, I’ve tried unplugging and plugging back in, I’ve also tried unplugging and holding down the light on/off button for 15 seconds as suggested in another comment. But regardless, the issue eventually comes up again. Any help is appreciated!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
3 commentaires
@Tessa Huffstater Do you know how to take the alarm clock apart?
par
No, I don't, I didn't try
par
Okay, I'm an experienced tech engineer, and after reading the thread I see no solution and no good insight about the cause, so I tried to dive deeper with this issue and make some studies. First, if you set up a new wake-up time right after the light fails to stay, for at least half an hour apart, it will work and stay for 1,5h after, then smoothly fades out. The most interesting thing if you set the wake-up time to the evening one, around 20.30 or something it is still wakes and stays! But as for the morning time it fails.
I tried to shift it's own clock for 12 hours, and set up two alarms, for 8.30 and 20.30. So the clock thinks it's morning when it's actually evening. And it still fails in the real morning and works and stays in the evening!
The only significant difference between these conditions I can conclude is ambient lighting (it has the light sensor which lets it know how bright the display should be), the sound sensor (it stops the sound if you make noise while it's singing), and temperature.
par
Ajouter un commentaire
10 Réponses
Solution retenue
No, I ended up calling Phillips to ask them about it and they gave me a 20% off coupon code to use towards the purchase of a replacement, so I got a new one. I’d bought mine like 5 years ago so it wasn’t warranteed anymore, so this seemed like the best case scenario
Indice 0
1 commentaire:
Mine started doing this after closer to 10 years. Took it apart, there does seem to be some of that glue that degrades and becomes conductive, so I'm going to scrape that out, clean up the mess, and see if that helps.
par
Réponse la plus utile
Similar problem. After alarm time is reached, lights goes off, display goes to maximum brightness. Disconnecting or performing the reset didn't help. The problem turned out to be in a faulty speaker (its one thing that is switched on when alarm time is reached). Without disassembling the clock fully, its possible to disconnect the speaker (after taking the bottom off). Then one can continue without the speaker or going further and replacing it.
Indice 1
1 commentaire:
Wouldn't disconnecting the speaker just make this a light rather than alarm clock? I think for this to be effective as an alarm you have to have the sound.
For mine, when it starts acting up I unplug it before I go to work. By the time I plug it in that night, it's reset and is good maybe another month before it acts up again. Seems to work for me. Maybe you need to leave it unplugged a few days over the weekend. Not a perfect solution but I'd rather not take it apart and maybe make it worse.
par
Had the same problem, pulled the plug on it yesterday and today it worked again, will be interesting to see for how long.
Indice 1
1 commentaire:
About 7 Days, did not work this morning. Are they made to fail? Really don't want to buy a new one after this.
par
I’m having the exact same problem. Did you find any solution?
Indice 0
2 commentaires:
Unplug for a half hour and plug back in.
par
Here the same, also this problem! Taking the current off did not help
par
I have the same problem. Unplugged it for a half hour and plugged it back in and that fixed my glitch for 6 days, now it’s back. The light obviously still works for me and you since the lamp turns on pre-alarm.
Indice 0
4 commentaires:
This worked for me at first, but the problem would start again after a while and I'd never know when the alarm would stop working again, and it started happening more and more often such that I couldn't rely on it as an alarm clock at all. I hope it fixes yours though!
par
My fix lasted 6 days and glitch returned.
par
My fix lasted 6 days and the glitch returned
par
My fix lasted 6 days and the glitch returned.
par
I'm in the same boat now, I bought mine second hand about 5 months ago. It "soft locks" and none of the buttons are functional until it's unplugged, though they do make a sound like they're being pressed. Has anyone had any luck with a repair?
Indice 0
1 commentaire:
Same!! What can be done? I've contacted Philips...
par
My issue kept happening more and more frequently (I think it got to daily). And then I just bought a new one.
Looks like my original lasted almost exactly 5 years. I couldn’t find a warranty of discount to get the second. I monitored the price on Amazon and got it for exactly $100 ($4 cheaper then I had years earlier).
My guess is that there is 4 years left on this new one.
Indice 0
Same problem. Disconnecting from the current does not help. I am looking for a solution to the problem through repair. I was surprised by the message about a speaker malfunction. The speaker works properly without distortion. I would be grateful for advice.
Indice 0
6 commentaires:
Same here. Speaker works, light works, both work at the same time. I can manually turn on the light at wake up time and light and sound works at the same time. It just stops lighting up at the alarm time instead of getting brighter.
par
If there are people who were able to solve this problem, please share your experience.
par
@klausnoecken Have you made sure the power adapter's voltage doesn't drop under load? Have you checked the current draw of the alarm when it's "going off"?
par
I tried another power supply, but did not get a positive result. In addition, I tried to turn on the backlight after the sound signal sounded; it can be activated manually. The process of the alarm going off is this: first a dim light appears, gradually it becomes stronger and at the very last moment the light goes out and the alarm melody starts. When a melody is playing, I press the backlight button and it turns on, while the melody continues to play.
par
@alexeyobraztsov Can you upload some pictures of the circuit board(s) inside the alarm clock? Ajout d'images à une question existante
par
Afficher 1 commentaire en plus
A SOLUTION IS HERE!
Same problem here. After alarm time is reached, lights goes off, display goes to maximum brightness. Disconnecting or performing the reset didn't help. As "professor" suggested, but was widely ignored, the problem turned out to be the speaker! (Although it was still working!)
Easy to test: remove one screw at the bottom, disconnect the speaker by pulling the small connector.
Now test the Alarm function. Light stays on at alarm time? Good!
Now connect anothet speaker and test again!
My 'defective' speake hat an Impedanz of only 3.2 Ohm. I replaced it with a 8 Ohm Speaker I had availabe.
Now the HF3520 works like a Charme again.
Good luck, wega
Indice 0
2 commentaires:
ALL BACK TO ZERO!
I'm very sorry but my "solution" worked only for two days, now I'm back to sqare one...
wega
par
My Philips Wake-Up light lasted about 9 years before acting up. Over a period of a couple of weeks, I tried all the resetting procedures mentioned by others and nothing worked for more than two days. Finally, I decided to try one other method. I had noticed that as the light got brighter, the failure would occur each time, so I tried a light setting of 12 on the 20-point scale. It worked and after about 3 days, I increased the setting to 14. That worked and after a few more days, I again increased it, this time to 16. That worked, and I increased the setting to 18. It has now been working with the light setting of 18 for two months with no failures. Here's hoping it continues to last.
par
Okay, I'm an experienced tech engineer, and after reading the thread I see no solution and no good insight about the cause, so I tried to dive deeper with this issue and make some studies. First of all I've replaced the power supply and it didn't help.
Then, if you set up a new wake-up time right after the light fails to stay, for at least half an hour apart, it will work and stay for 1,5h after, then smoothly fades out. The most interesting thing if you set the wake-up time to the evening one, around 20.30 or something it still wakes and stays! But as for the morning time it fails. It's more likely for him to wake and stay if the brightness is less, as one of the guesses here says, you may "train" it at a lower brightness, but I need the brightest setting.
I tried to shift it's own clock for 12 hours, and set up two alarms, for 8.30 and 20.30. So the clock thinks it's morning when it's actually evening. And it still fails in the real morning and works and stays in the evening! Even with the brightness of 20.
The only significant difference between these conditions I can conclude is ambient lighting (it has the light sensor which lets it know how bright the display should be, and it's controlled with the CPU, so during the fail the display is bright), the sound sensor (it stops the sound if you make noise while it's singing), and the temperature in the room.
Indice 0
Ajouter une réponse
Tessa Huffstater sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 31
7 derniers jours : 53
30 derniers jours : 164
Total : 9,725
