Why is my car getting wet in side,since I had the oil change and tire
Why is my car getting wet in side after a oil change and tire rotation
If it getting wet on the passenger floor board it's the ac evaporator drain line that's loose or plugged. It could also be coming from under windshield that's where the air comes into the car. Check if you have leaves or debris blocking the area or can cause the water to go into the vehicle. That's what I would check first
This has nothing to do with the oil change or tire change. Hopefully you've solved the problem by now... Water leaks can destroy a car quickly. Another common entry point is the sunroof weep holes. The gutter around a sunroof drains into one or two small weep holes, which are in turn connected to rubber tubing. This rubber tubing is routed inside the A-pillar, and ends either in the door or in the side kick panel (wall space North of the door, so to speak). The cavity inside the door or kick panel also has a drain to outside. Sometimes, that final drain hole can become clogged with debris and cause the drain water to overflow and exit inside the vehicle. If that happens, you would notice water on the floor, in the front of the vehicle. If this sounds like your problem, a think stiff wire can be used to unclog. But you might need to remove interior paneling to access the clog.
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 246
Need more details to narrow down possible causes. Where is it getting wet? Can you tell where the liquid is coming from?
par brandon k
