Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Appareil photo numérique compact de 8,2 mégapixels.
Why cant I turn on my camera
when i try and turn on my camera i will not be able to push that botton because its stuck.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
1 commentaire
We are having the same problem. One day the camera was working fine then it just locked up. It seems that the on off button is not responding. We have changed the batteries but it did not help
par Partager
Ajouter un commentaire
2 Réponses
Solution retenue
Follow this guide up to step 10 and see if the actual button has been dislodged. Once you have gone that far, check the switch without the cover and see if you can "feel " it click. Check for the plastic button in the cover and see if it cracked, broken or if you can loosen it. Hope this helps to get you started
Indice 5
My lens is showing error.My lens is not closing.
Indice 0
Ajouter une réponse
smithtamara69 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 44
Total : 8,126
