Why is my replaced battery draining quickly and charging slowly?
I recently replaced my battery through ifixit. It seemed to be working fine the first discharge, but after i charged it again, it seemed to drain very quickly (quicker than my old crappy battery I replaced). It also seems to be charging slowly (I had it on the plug for about 3-4 hours and it only got to 80 percent). Is this normal for a new battery? I tried resetting the SMC and that didn’t seem to fix anything.
The process of replacing the battery was very straight forward and I will definetly be purchasing from this website again.
Additional Pictures:
6 commentaires
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante
par Dan
@danj Hi, Dan. Thank you for your reply. I have attached a screenshot of the main window to my original post.
par Christian P
@Christian P - Sorry did you drop it into the image toolbox and not plug it into your question (go into edit mode) or just create a new answer then when you save it (with some text as well) You'll be given a small menu select Update and then one more time to save!
par Dan
@danj sorry, I hadn't put my cursor in the right spot. You should be able to see it now
par Christian P
@Christian P Good, now plug in the charger give it a good 4-5 minutes and take a second capture, also lets see the battery info in this capture too!
par Dan
Afficher 1 commentaire en plus
