Aller au contenu principal
The Jeep Liberty is a compact SUV that was produced by Jeep for the model years 2002–2012.
Questions au sujet de 48 Voir tout
Will this procedure program my new FOB Key when only have one orig key
Ron T <jlodoggy1@gmail.com>
6:23 PM (5 hours ago)
Programming a Single Key
 This is what I have  a Jeep Liberty 2011 low miles mint with one working Key fob because the other key chip they used to hide under the dash for my electric start  , so now with one working Key Has anyone proved out this  procedure will work with one new cut  Fob Key that's not programmed yet .should I take a chance to do this?
A handful of manufacturers will allow you to program a single key, even if you don’t have a key that works. Keep in mind that you’ll still need to have the key cut to fit the ignition, which means you’ll need to provide proof of ownership to a locksmith.
That said, the process is much simpler than programming a second or third key:
  • Insert the key into the ignition, and turn it to the on position. Don’t turn on the engine, only the electronics.
  • Leave the key in this position for 10 minutes and 30 seconds, and then turn it off.
  • Turn the key back on, and wait for additional 10 minutes and 30 seconds before turning it off again.
  • Repeat the process for a third time.
  • Return the key to the on position, and it will program the key.
  • Test your new key by turning on the ignition
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
THANK YOU what I did was buy a blank FOB had it cut then went to a locksmith and they programmed, I should have tried the advice above first however I didn't know this .
par
Ajouter un commentaire
1 Réponse
Honestly the easiest and best way is to find a locksmith and they can program a second FOB for about $50—$90 (depending on the FOB cost.
Indice 0
Ajouter une réponse
Ronald Tyler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 33
