Aller au contenu principal
Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
I am curious if you found a good solution for this?
par
@grayraver See oldturkey03's answer
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
Indice 1
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
Indice 0
Ajouter une réponse
Randy Northrup sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 34
Total : 434
