Aller au contenu principal
Repair guides and support for televisions manufactured by Sony.
Questions au sujet de 649 Voir tout
XBR-55X900E Four red blinks.
My tv developed a problem where it will power on and the shut down. Once shut down it blinks red 4 times. It will power back on and then does the same thing. I have replaced the bmks board and ld board. Any insight as to what is going on? Also if anyone has the capacitor layout for the bmks board that would be helpful. The service manual has two listed but i cannot find a diagram.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@jamesla the 4 blink code is an LED driver failure/LED voltage protection [LD_ERR] Error detection of the I2C communication between the Main device and the LD IC. Most common failure is the LD board or the actual backlight strips. Follow the flowchart to determine if it is the LD board or the BMKS board.
. Post some good pictures of your BMKS board with your question so that we can try and help you with those caps. Ajout d'images à une question existante
Indice 1
5 commentaires:
Thats the flow i was following, i have two bmks and lds now. I was wondering where the location of c464 and cl1036 were located as referenced. Hoping its not the strips.
par
My TV does the same thing except sometimes you can unplug it and it’ll work for a movie or two and shut off and sometimes it will come on display the opening screen and then shut off
par
@michael vaughn make and model? Blinks 4times after?
par
I have same question. Layout of bkms board doesn’t seem to have c464 or cl1036. Board 2170473a.
par
@bobbabcock same model? Same error? That is one of those cases where we ask that "Post some good pictures of your BMKS board with your question so that we can try and help you with those caps. Adding images to an existing question" so we can see what you see :-)
par
Ajouter une réponse
James Lamb sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 92
Total : 1,388
