Aller au contenu principal
Le smartphone troisième génération de la marque Pixel par Google et leur tout premier téléphone "à encoche". Équipé d'un écran OLED QHD+ de 6,3 pouces et d'un stockage de 64 ou 128 Go. Disponible en Résolument Blanc, Simplement Noir ou Subtilement Rose.
Questions au sujet de 72 Voir tout
After battery replacement finger print sensor stopped working
All instructions followed to replace battery with Pixel 3 XL. Fingerprint sensor cable was last connected before closing the back cover with adhesive applied. Now the phone no longer shows the Pixel Imprint option to enroll the fingerprint. Any suggestion?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Hi,The fingerprint sensor is very fragile you may have broken it during your repair.You could replace the fingerprint sensor or take it to a local repair shop for a diagnosis
Indice 0
2 commentaires:
Dear FIXIT:
Any suggestion to diagnose this issue? or it's safe to assume that if Pixel Imprint function/option is not showing up in Security Setting anymore then I probably had broken the Fingerprint sensor cable somehow during the battery replacement process?
Appreciate your further comments.
par
Hello! Did you manage to figure out this issue? I am facing the same thing after replacing my battery and daughterboard. The fingerprint sensor and its connector don't show any physical signs of being broken (but tough to say how fragile is very fragile :-D ). Did you solve the issue by replacing the fingerprint sensor? I am trying to check all the boxes before I order a replacement and go through the entire back panel adhesive extravaganza again.
par
Hi, same problem here. I think Ifixit should take a look because selling the batteries they should advice on how to avoid this to happen because it has happened to several people as I'm reading everywhere. In the tutorial you posted to try the official google fingerprint calibration tool which only work for pixel 6, 6 pro and 6a.
Indice 0
2 commentaires:
Same happened to me after changing battery on Pixel 4a
par
Même problème pour moi. Je vais essayer de changer le capteur d'empreinte
par
Ajouter une réponse
CharlesCW sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 51
Total : 512
