Aller au contenu principal
Le OnePlus Nord est un téléphone milieu de gamme lancé en 2020. Il dispose d'un 6,44" 90 Hz Fluid AMOLED, fonctionne avec un Snapdragon 765G avec 8/12 Go de RAM, 128/256 Go de stockage et fournit quatre caméras arrières et deux caméras frontales.
26 questions Voir tout
Does the Glass Back Cover Adhesive need to be replaced on reassembly?
Hi there,
I was about to take my OnePlus Nord back cover off to test something with my vibration motor and realised that I might have to replace the adhesive when putting things back together. I am new to taking phones apart that use glue, so I wasn’t sure how this would work, especially since the Nord doesn’t require a heatgun to remove the back.
Do I need to replace the original adhesive before putting the rear cover back on, or does it fit back together without doing that using other connectors or possibly the original adhesive?
thanks,
Yannick
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Would recommend getting adhesive for water-resistant but you should just be able to slap it back on if you really need to
Indice 0
1 commentaire:
Hi @consistent ,
Thank you for your answer. I do actually need it to be water resistant, because I use my phone a lot on my motorbike.
Would you say removing the adhesive with acetone and then using one of these to put it back on would work?
Tesa 61395 Tape
Polyimide Tape
Do you know what type of adhesive or glue would be best and also keep the water resistance?
Thank you!
Yannick
par
Ajouter une réponse
Yannick sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 23
Total : 333
