PS4 Drive Disk won't work
Hello everyone!
My ps4 [FAT - cuh-1115a] always had some small problems with the disc drive/eject. At first I had to struggle a little for my disk to be accepted by the drive and one time I had some auto ejecting problems but those problems stayed for some months and then stopped. Some months after It went back and then stopped again so I didn’t care much.
After a long time without those problems. Last week I’ve tried to put a disk in and the PS4 wasn’t pulling at all then I started my research and did some things:
- Cleaned the disk drive - used isopropyl alcohol at the rollers
- Forced a disk inside but the drive won’t read then I removed with the screw mechanism
- Tested the eject receiver at the disk board and it wasn’t responding
- Tried the Rebuild database option and update in safe mode (I bought this ps4 with another disk drive problem that was solved with safe mode update)
- Bought a new flat cable then I tested with just the flat + 4 pin and the beep works with pretty low volume but It’s giving some info.
If I plug the other disk drive flat cables the eject receiver and the drive don’t work so I guess it’s not receiving enough power. My guess is the 4 pin cable but before I look for one I’m sharing my problem so you guys could give me an opinion and more things to test.
Thanks in advance :)
