Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
6 commentaires:
Hi,
Does this happen regardless of the location of the phone i.e. it may only happen in a poor reception area?
Do other phones, using the same network as yours, have the same problem when in the same location as your phone?
@jayeff hello, it actually happens all the time. Other phones using the same network works so well including my other phone.. And also data connection is always EDGE.. it does not show a 4G connection.. I just don't know if it has been dropped..
Hi,
Has the phone been dropped or gotten wet at all?
par jayeff
par Chel Bete
@Chel Bete
Check what the network settings are.
Try 3G/2G auto and check if the signal is stable.
par jayeff
@jayeff thank you.. I will try to do it... Will update you...
par Chel Bete
@jayeff good morning. I did what you told me, signal is now stable but data connection stays EDGE.
par Chel Bete
Afficher 1 commentaire en plus
