Aller au contenu principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
Questions au sujet de 172 Voir tout
Surface Pro 4: New Battery, powers+charges only while plugged in
I installed a new battery in my Surface Pro 4 (didn’t see an option for that device). I plugged it in, powered on smooth, and charged up to 100% to begin calibrating. Once I unplugged it to continue calibrating, it goes immediately black and I have to plug it back in to reboot. I’m certain everything plugged in correctly, I followed the video closely. To my understanding, the battery “tab” just slips under the board and sits underneath the tabs to connect. Am I correct in thinking this, or have I made a dire mistake?
Taskbar icon has a plug and a full bar (didn’t start out full when I first started up), so it is recognized and taking a charge. Battery diagnostics recognize a battery is connected. Is it possible the battery could be defective? Or do I need to crack it open again and check on something I may have overlooked.
Répondre à cette question J'ai le même problème
Indice 1
Commentaires:
Hi,
Don't know the laptop, but looking at Step.48 of the ifixit Remplacement de la batterie de la Microsoft Surface Pro 4 guide, it shows that the battery connector is glued down to the case. Maybe a loose connection if you didn't glue it back down.
Just a thought.
par
I did, it has an adhesive section that I slid under the connection to the board.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hey, I think the problem in this thread looks similar to yours!
After replacing sr pro 4 LCD,won't turn on battery mode unless plug it
Indice 1
Ajouter une réponse
Mitchell Nuyens sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 44
