Aller au contenu principal
La PlayStation 3 Slim est la deuxième version de la console de jeu vidéo PS3 produite par Sony Computer Entertainment. Elle est sortie le 1er septembre 2009.
465 questions Voir tout
Stays powered on as long as I press down on the disk drive
I have a PS3 slim. Model chech-3001a. Plug it in and the red light comes on. Press power button and the green light and fan come on for a few seconds then shuts down with no lights. If before I press power button I push down hard on left side of disk drive and hit the power button it will run and stay on. If I let off a little pressure it will shut off again. I took it apart down to the motherboard and looked over with a magnifying glass. Checked for solder connections and for damage. Did not see anything wrong. Anyone have any idea? Thanks
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Have you checked that the controller board for the disc drive is connected properly?
From what i understand, most hardware in the slim is held thru tension from the case screws, kinda sandwiching all the components, if that connector is the culprit and you only need a bit of force on it, you could try to put a soft piece of foam between the drive and the upper case to add that little extra tension you need, but first check that it's seated properly.
There is a teardown on this page for this device, on step 19 third picture you'll see the connector
Indice 2
2 commentaires:
Hi David. Thank you for your answer. I checked the connector and the drive is seated in all the way. Tried the foam, built it up to get down pressure and still did not work unless i press down hard on the left side of the disk drive.
par
On the side you need to push on you need to put foam there as well
par
The HDD wire is probably dirty or broke?
Indice 0
1 commentaire:
I changed the hdd and disk drive and added foam for pressure. Still same problem.
par
Ajouter une réponse
Tom Casper sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 46
