Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1921, A2101, A2102, A2104. Disponible avec GSM ou CDMA / eSIM ou nano-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S Max".)
Questions au sujet de 311 Voir tout
Error showing "Unknown part" after battery replacement
After replacing the battery in my iPhone XS Max, an error message "Unknown Part" appeared in the settings.
The Settings>Battery>Battery Health cannot display battery percentage.
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
3 Réponses
Réponse la plus utile
This is normal behavior and is another way for Apple to discourage people from repairing their own devices. A warning is displayed in the introduction of the iFixit guide for battery replacement on this phone. If your phone is acting normally, you can safely ignore this warning.
Keep in mind that Apple continues to make moves like this that hurt the repairability of their products. Replacing the screen, battery, home button (if applicable), and/or front sensor assembly (on iPhones with Face ID) will trigger a message or cause some functions not to work on many iPhones and other Apple devices. Some tools, like the JC V1S, will restore the battery health functions but may not remove the "battery may not be genuine" message.
Serialization of parts is one of the things trying to be fixed by "Right to Repair" laws. You can learn more about Right to Repair under the Advocacy section on the footer of the iFixit website.
Indice 4
3 commentaires:
Not only do you loose battery health - but now I can't download and install new OS updates. I'm stuck on 15.5 since Aug 2022 iPhone 11. Really upset with this.........
par
@Junior Hernandez That is a separate issue. I have never experienced lack of OS updates due to a battery issue. Have you tried updating via iTunes/Finder?
par
@Junior Hernandez i had the same problem until today. I gave my phone the OS Update with my computer.
par
There's a small board attached to the anode/cathode of the battery.
For a DIY repair, you'll need to transfer this board from the original to the new using a spot welder.
Then a programmer to reset the charge cycle of the battery.
Totally unrealistic/not cost effective for a one off at home, you would need a really good, reputable repair shop to carry this out.
Indice 3
2 commentaires:
After the battery was replaced by a local Fix Shop i noticed the battery unknown message and later found out that the original battery BMS board needed to be install on the new battery. Really upset about this....... Apple thumbs down
par
Welding on a lithium battery has the risk of it blowing up in your face. I don’t think a repair shop will offer this any time soon
par
Unknown part battery
Indice 0
Ajouter une réponse
Hossam Zanaty sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 209
30 derniers jours : 862
Total : 10,841
