Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Dyson V8 Animal est un aspirateur sans fil doté d'une aspiration puissante pouvant durer jusqu'à 40 minutes sur une seule charge.
My dyson doesn’t hold a charge for long also when using it plusats
My dyson v8animal plusates when using and doesn’t hold a charge for long yet it has 3 full blue lights showing I have also replaced the battery but made no difference
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
It probably just needs filter cleaning. The pre filter on the top can be pulled out and rinsed with tap water. My V8 had similar pulsating problem and lost suction power. Replacing battery didn't help. Then I found out that yt was just a clogged filter. Cleaned it and put it back. Problem solved! Works as good as new.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Remplacement de la batterie du Dyson V8 Animal
Indice 1
Check that you inserted the screws tightly after replacement. It could have been a bad battery at first, but then you probably replaced it and inserted the screws too loosely after putting in a new battery. If not, it is perhaps that you are using Max Mode too much.
Indice 0
Ajouter une réponse
Charlotte mallard sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 15
Total : 571
