Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations pour réparer et démonter l'Apple Watch SE de 1e génération, annoncée le 18 septembre 2020.
2 paperlike connections next to display ribbon cable
Hello!
What are the paperlike connectors that seem to be a part of the display connector but are next to the 3 ribbon cable connections? Can these be purchased? When I look online for the display cable, it simply only comes with th 3 main connectors and not the 2 outside paperlike connections.
Thanks for your help!
ML
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Still no idea where to get a replacement
par
Ajouter un commentaire
1 Réponse
Solution retenue
The two outer connections are EMI shield connections for the cover piece. Here's a better picture
Indice 2
3 commentaires:
Thank you for the picture! If these are torn, is there a way to fix them or order them?
par
@Michelle Londeree - It's a big job to replace, they can be gotten. I don't fix the watches anymore so I can't aim you to where to get them.
Patching the connection is difficult as the electrical pathway between the two cut segments needs to be made to be effective for EMI.
Many people just don't reconnect them if they damaged them in the repair process. The trick is not to damage them in the first place.
par
Ah! Don't damage them! That's super helpful!
par
Ajouter une réponse
Michelle Londeree sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 51
Total : 612
