Aller au contenu principal
Le smartphone standard 2021 d’Apple. Commercialisé le 24 septembre, l’iPhone 13 est muni d’un écran OLED de 6,1", d’une caméra double de 12 MP et existe en cinq couleurs. Il succède à l’iPhone 12.
Questions au sujet de 39 Voir tout
Does replacing the Proximity Sensor flex cable disable face id?
As most of us know, any Apple device with Face I.D. functionality has that functionality linked to the front camera assembly and the proximity sensor flex cable. In past generations, damaging the proximity sensor flex was relatively easy to do on accident, and rendered Face I.D. disabled unless you employ micro-soldering to transfer the flood illuminator to a new flex cable.
I have been searching for an answer about this on the iPhone 13 series. When these phones were first released, screen replacement would disable Face I.D. unless an IC chip on the back of the display assembly was transferred. This has since been changed, but I do not know about the proximity sensor flex. No tutorials or guides that I have found have mentioned anything about transferring the proximity sensor flex cable, so that leads me to believe that it's not necessary anymore as long as you have another one.
So my question is this: Does the proximity sensor flex cable need to be transferred to retain Face I.D. functionality as it has in past generations, or is it no longer linked in the same way that it used to be?
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
2 Réponses
Réponse la plus utile
This shouldn´t affect the face id function, after apple made the proximity sensor a totally seperate part so it should work!
Indice 2
Face ID is a part of the True Depth sensor for which Apple has made separate flex cable for on the iPhone 13 and other models, including some previous generations, meaning the replacement of the proximity sensor does not affect Face ID. Any case of misuse may.
Indice 1
Ajouter une réponse
Garrett Chism sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 99
Total : 517
