Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1687/A1634. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
1033 questions Voir tout
Replacing Nand Flash with higher capacity without restoring
As the title says, I want to replace the Nand without updating ios. Most threads I have seen is people having fail nand flash memory.
i have experience on how to replace its nand flash, but usually the new nand needs to be erased and programmed in order to work.
but my case is if I have a working 32gb nand and I want to upgrade 256gb nand. Can i clone the contents of 32gb to the other memory? Would that work? Because i dont want to hit ios 15 because theres no jb for that version
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
I also have the same problem, I wonder if it is possible with a nand programmer to extract a disk image file (encrypted of course) and then be able to flash it on a larger nad. This way the iPhone should recognize it as it is always encrypted, but I have no idea how to do it 🤯. @tomchai I think he can help us 😬
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
the data on the nand that the phone is using now needs copied to the new nand in order to work. you could download a lower ios and flash it using 3utool.
Indice 1
1 commentaire:
Wouldn’t it still need to be signed? Which would still leave you at 15.4.1 at the time of writing which has very little progress in terms of jailbreak.
par
Ajouter une réponse
ryeisqt sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 33
Total : 471
