SOLVED Err Flashing, Flash doesn't pop up, no AF, no DoF preview
Hi There,
I have a problem,
When I switch on my Nikon D80
On the LCD "Err" is flashing.
THe Flash doesn't pop up
The AF Doesn't work
The DoF preview doesn't work.
But the shutter works, but no images are stored.
Sometimes the Mirror stays up, until I take the next picture.
I Have a Service manual, but this error isn't discribed.
I somehow managed to work for 10 Pictures but then the same happened again.
Any Idears, what could be the Problem.
I Hope you can help me.
Best regards
ULY
SOLVED - Finally, It is working again!
Technician X was right... it was the phase switch in the Aparture Unit.
I found this thread:
http://www.nikon-fotografie.de/vbulletin...
I had exactly the same probleme:
The contact plate on the ecoding gear wasn't properly fixed.
One of the plastic pins werent melted down on the contact plate, so it was loose.
one drop of superglue solved the Problem.
After reassambling everything works fine again.
Thank you for your Help.
ULY
