Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz) ou 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
465 questions Voir tout
How much time before I need a battery?
I realize this MacBook Pro is bordering on obsolete being a 9 year old model, but I've been very happy with the machine and don't feel the need to upgrade for a bit longer. However, my battery is beginning to show its age.
How much longer does it look like I have on this rMBP before it is time for a battery? I bought the machine used as a buffer between the 2012 13" aging, and the 2016-2019 Butterfly and USB-C only disaster machines, so I don't know how well it was cared for between me and the 1st (as well as a likely 2nd) owners. The difference at the time was minor, but both the 2014/15 are about the same in terms of age.
Turns out it may be more due then I though :-(. Loses 2%/charge.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
You can replace it if you want, you still have a couple of years of OS compatibility before you drop off the update bandwagon. You can of course use it for longer, though you'll have to use Firefox or some other still-updated browser for security reasons. And you'll want to exercise more caution in general.
But your battery has time on the clock, but not a lot of miles. You've been good to it. If it were mine, I would wait. I'd hate to replace my 87% battery and get an expensive failure a few months later.
Lithium batteries have five enemies:
# Time. Nothing you can do about this.
  1. Cycles. Yours are low. My MacBook pros have always been used as desktops, so they have low cycle count. Keeping it connected to the charger reduces cycles, but can lead to problem 3:
  2. High voltage. Battery degradation is accelerated while voltage is high. Fortunately, Apple has moved to adaptive charging, which notices that you're a desktop guy, and stops charging before the cell voltages get too high (at about 80%). Most or all modern laptops do this, though sometimes it is manual, not automatic.
  3. High temperature. Don't leave your MacBook in a hot car.
  4. Low voltage. Really low, less than 2 volts/cell. You can't run the cells down this low, the battery management system shuts you down long before then. What you can do is discharge to shutdown, then put it on a shelf for several months, where self-discharge will do it for you. This is not degradation. This is death. Once the cells get that low, they are unsafe to charge, so your battery management IC kills the pack.
Indice 1
You have two things coming at you age and cycles!
The age of your battery is now over seven years old (2015 - 2022) for a battery which lifespan is about five years.
The cycle count is 233 currently, this battery has an expected cycle of 1,000 cycles (+/- 10 %) Determine battery cycle count for Mac notebooks
So I would say its already on borrowed time! Time for a fresh battery. You should be able to get at least 5 more years if you give it the needed TLC.
Indice 0
7 commentaires:
Only reason I haven't changed it is the process stinks to do so, especially for the age of the laptop. I know I'm coming up due to the age of Haswell, but the 2014/15 is still a very fast machine. The main issue why I checked is the runtime took a partial nosedive as well (used to get 6-7 hours, now it's 4-5 in some cases).
The reason I still have it is the antiglare issue tanks the value on these very quickly (and the replacement display totals the machines out), so the resale I can get combined with the age of the hardware depreciating is bad enough I'm still using mine.
par
@nick - Its not that hard, yes its a bit of a pain but its well worth it! I just did one of my 2015 15" systems as its battery was ~780 cycles and not holding a charge.
par
@danj The cycle count was why I held off as it is EXCELLENT for one of these, but the runtime hit was an early warning I needed to monitor it.
par
@nick - Don't read to much into the cycle count. Age is really the more important!
Sadly, Apple doesn't warn people about that as they would shoot Apple holding back that important piece of info!
Cycle count becomes an issue when the battery is young (a few years old) some people run the battery fully down then fully charge it every day. So about 250 work days per year (one cycle per day) thats four years flat-out! Many road warriors do this working on a train or bus or on the side of the road when visiting clients.
par
@danj I've always been careful not to run it down past maybe 15% tops before recharging it under my use. The problem like I said is I doubt the previous owner(s) took that care with how my runtime nosedived. My runtime problem happened after the first YEAR I used it, so I got a good ~11-12 months on it with an easy 6-7 hours.
I would rather look like the "weirdo" for charging a laptop which can run all day, then tank the thing.
par
Voir 2 commentaires en plus
Ajouter une réponse
Nick sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 121
