Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'imprimante M3D Micro est une imprimante 3D abordable au format compact.
Help recognizing burned component
Hi M3D Micro owners!
I have recently noticed one component (I think is a transistor) is burned, and I need help knowing which one it is.
I didn't find any schematics for the board, so I have no clue.
I would really appreciate any help here. I want to replace the component and fix the printer.
Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
4 commentaires
Which board is this? Is this the logic board or the Power and Data board?
par
I think my Micro is the first one they released, since I bought it from Kickstarter. Therefore it only has one logic board.
I have edited my comment, adding the full board image.
Thanks Jacob!
par
Это стабилизатор питания на 3,3V для микроконтроллера. Если его пробило, через него мог сгореть и контроллер.
This is a 3.3 V power stabilizer for the microcontroller. If it broke through, the controller could also burn through it.
par
SOT-23 XC6206P332 or XC6206 or SMD(662K) 3,3 В/0.5A
par
Ajouter un commentaire
2 Réponses
Solution retenue
check out this datasheet
https://www.diodes.com/assets/Datasheets...
GW9 = AP2127N-3.3TRG1 = 3.3V regulator
Indice 4
3 commentaires:
@ruggb same result for me. Got the right symbol and right marking.
par
Thank you! I think you have found it! I will order the component, replace it and let you know.
par
I found a cheap option to order it from Europe, if someone else is interested:
https://a.aliexpress.com/_uv6bsR
par
Hi @kuruchy
For what it is worth here's a zoomed in image from Step.7 of the ifixit Changement des ports de données et d'alimentation de la M3D Micro which shows the component.
Although what GW9 (I think) means I don't know. Looking at this link it may be some sort of voltage regulator?, but as to its value that is also something else, I don't know.
Then again it may just be the component manufacturer's marking and not a value marking
(click on image to enlarge)
Hopefully a start
Indice 3
4 commentaires:
hi @jayeff, thanks 👍.
Taking a look at the circuit itself, and how it got burned, it makes total sense that it is a voltage regulator.
With GW9 at least I have a hint on how and what to test.
par
If anyone has more info to which component exactly is, would be great.
par
Taking a look at all the manuals you added, it could also be a voltage detector.
par
@kuruchy
True.
Long shot perhaps but looking at the image you provided are there any other similar sized ICs on the board having the same marking as the faulty one?
Sometimes more than one may be used in a circuit.
If there is it may give some idea as to what it might do, depending on where it is situated.
Very hard to know without a schematic. ;-(
par
Ajouter une réponse
Bruno Retolaza sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 710
