My touch screen stopped working after battery replacement
I did a DIY battery replacement and followed instructions carefully. I tested the screen by turning the phone off before closing up the phone everything went well. But when I sealed up the phone and turned it on something was wrong. My screen turned on and was visibly perfect and the battery was working. My buttons all work and respond but touch is gone. I can’t type in my password or open up my phone. Does anyone have any suggestions on what I should do?
4 commentaires
So long as you're sure the digitizer's connector is attached properly, the odds are it's physically damaged.
par Krzeszny
What is a digitizer connected? Yes the things snapped properly, I redid it a few times to be sure. Do you think I should order a new screen? @krzeszny
par Killua
@babylaven Digitizer's connector is seen in Step 21 here: Remplacement du panneau frontal de l'iPhone 6s Plus
Before you order a new digitizer, make sure it's not a software error caused by disassembly or reassembly. I'm just guessing, as I've never had an iPhone. Or try finding answers on different websites. But I'm pretty sure the digitizer has indeed been damaged.
A workaround would be to use an external mouse (and maybe a keyboard) until you fix the smartphone.
par Krzeszny
@krzeszny I looked that up and I see that I should do the factory reset (power button and home button). I've done that and the screen still won't respond. I agree that the digitizer is most likely indeed messed up since the home button and screen light up. I have ordered a new one so I will see how that goes and update on that. Thank you so much for your responses!
par Killua
