It's not power on
It is unable to switch on the phone
Galli Boy Naresh besides the excellent request for more information by @geirandersen you need to start assessing this symptomatically. Check the charger first, then the charging cable. After that check the charging port. Attach an USB Ammeter to see if your phone even makes any effort to charge. If that works, you need to check and possible change the battery. Of course, you can also try reset (use instructions from places like this or even a factory restore (instructions on same site (YOU WILL LOSE YOUR DATA)). If none of that works, follow the Samsung Troubleshooting flowchart. You are now getting to the board level of your phone. You will need the tools and skills to check some really small parts :-)
Since there are various models for your phone you will need this file Board Layout. Use your PDF reader to search for the part location on your board based on the flowchart.
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 163
1 commentaire
We would need more information about what has happened.
- Has the phone been damaged (drop / liquid)
- Has it been repaired and now it's failing
- What have you tried
- Did it just turn off and now wont turn back on
The more information you provide, the easier it is to help you!
par Geir Ove Andersen
