Aller au contenu principal
Lancé le 20 septembre, le smartphone 2019 d'Apple est doté d'un écran OLED de 5,8 pouces, d'une caméra arrière à triple objectif et d'une autonomie de batterie considérablement améliorée. Il succède à l'iPhone XS.
Questions au sujet de 109 Voir tout
Face ID not working after changing the screen
Hello, After changing my iphone screen i bought from ifix it the iphone disabled the face iD feature. Also, i replaced my battery with one from ifix it a went settings> about and it says unknown part for both screen and battery
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
did you transfer the original front flex this can cause face id issues if its not original or has been damaged, the screen and battery will show unknown part if its not the original part for that phone out of the factory. to fix the screen issue theres a chip on the old screen that needs swapped over to the new screen and pretty much the same for the battery it needs the bms circuit from the old original battery transferred over to the new battery and programmed
Indice 1
2 commentaires:
The ifix screens already comes with front flex attached and glued. Not sure if i can remove it then place the original one ? For the battery what is the bms circuit?
par
@bader7 the bms board is the circuit board that is on the battery that the battery flex is connected too. using a 3rd party front flex will stop face id from working so thats probably your issue there.
par
I had the same problem, I found that after a factory reset via macOS, and updating to iOS it immediately began working.
Hope this Helps :)
Indice 0
It is always best to use a machine like an Apollo to transfer the Data from the Old screen and Battery to the new one. You will also have to reset the battery cycle to zero after transfer.
Indice 0
Ajouter une réponse
Bader Alturki sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 123
