Removing Moisture from INSIDE Camera Module
Hi all,
Dunked my phone in a pool after a screen replacement - moisture seeped in through a small break in the adhesive sealer. I was able to crack open the phone and get all the moisture out with one exception - inside the main camera module itself. It seems that the camera module's ability to move somewhat compromises its water integrity, and as such I can see some small bubbles on the inside of the module itself.
Here's a handy dandy pic.
I've already run a fan over the camera module for several hours, but no luck. I've also wiped it with a microfiber - it's definitely inside the module itself.
Anything to be done here? The rest of the phone works fine, except for the TrueDepth Camera which is borked. I can live without Face ID for a few months while I wait for the 14 to come out, but a camera right before a big vacation... unless I can fix it I might have to shell out the $200 insurance deductible.
1 commentaire
Unless you're an expert cellphone repair tech with access to technical info, your options are few; leave it alone and pay for repairs or experiment on dissembling whatever's necessary for access to sop up moisture inside the lens and CMOS image sensor with a Q-tip. Meddling in precision camera components may result in misalignment possibly resulting in out of focus images or permanent damage. Dissembling cellphones may be analogous to attempting watch repair of mechanical movements.
par F Dryer
