Switch not connecting to TV - Years long problem
Hello. Kinda new here.
So my nintendo switch has had an ongoing problem for nearly 4 years, which is about as long as ive actually had it. It doesn’t connect to the TV whatsoever.
Ive tried 3 TVs and a kinda older, but still great monitor, and nothing. However, when it does actually show up, it only lasts for a minute then completely stops.
A few days ago, i tried it out again with my main TV and the monitor again, and it once again only showed up for a few seconds, but i accidentally wiggled the cable and it showed up a bit longer.
I genuinely thought it was a problem with my dock, so i got a 3rd party one (CharJenPro) and ive gotten the exact same results. (I accidentally misplaced my og dock and i have no idea where its at, so the 3rd party one is the one im kinda forced to use rn)
Both dock lights show up, they work, but theres nothing to the display and no sound either. I have tried nearly EVERY solution and nothing has worked, and if it did, it only lasted a few minutes.
Plugging it in the official nintendo way, using a dab of alcohol on the ports so theyre clean, using different HDMI cables (i tried all of the ones i own, 4 , and same thing), using different ports on the same display, and recently, using compressed air. Nothing.
Im now convinced its not the dock’s fault anymore. I think it could be the USB-C port being faulty. I checked with a light to see if anything was bent, and while i didn’t see anything, i could be missing very small stuff.
What do you guys think? Getting a new system is my very last resort since i dont have money to just buy a new one rn. Much rather have just a replacement port or something.
Thank you.
2 commentaires
Bought the switch a few years ago for my grandkids, after about the first year it stopped connecting to the tv. It worked great just not connecting to the tv, so bought a knock off dock… still nothing. Frustrated because we’re stuck playing using the handheld to play rather than being able to share the fun. Any suggestions are appreciated!
par george_alaska@live.com
my Switch, after a couple years developed the same problem. I suspect it's the USB-C connector on the Switch as well.
Weirdly, it will output if I plug in a cheap USB-C hub that also does power delivery and HDMI out. But it doesn't work with three different official nintendo docks.
par Mark Kundinger
