Aller au contenu principal
Manufacturer says to replace amp
Hello, I have been having some problems with my Klipsch "Sub 8" (is the only identifying mark I can find on it)
The manufacturer has sent me a replacement amp that is supposed to go inside the subwoofer. Does anyone know of any possible guides out there to help me out? Thanks
Une réponse ! View the answer J'ai le même problème
Commentaires:
They didn't provide instructions? Can you ID the sub woofer HERE ?
par
Ajouter un commentaire
2 réponses
Solution retenue
Is this what your Sub 8 rear panel looks like ?
If so then you should be able to open it up easily by removing the screw around the perimeter and gain access to the amp inside. You may need to do some de-soldering to remove the amp board though.
Cette réponse est utile ?
Score 2
Commentaires:
Yep. Thats the one :) Thanks for the help :)
par
usually all wire coming with contactor or clips and the high amp point will soldring with bord so write and put marks befor remove any wire from the bord and repite that with new one
Ajoutez une réponse
tylr6024 sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,080
