Aller au contenu principal
The Xbox Series X is Microsoft's next-gen 4K gaming console. The Xbox Series X was released alongside its companion console, the Xbox Series S, on November 10th, 2020.
Questions au sujet de 36 Voir tout
HDMI pin 18 trace ripped
Hey I'm having trouble locating where pin/pad 18 connects to the circuit board, I have a pulled pad on the board 3rd from the last on the right I believe to be pad 18. I can't seem to find any videos where someone has had a similar problem. I just can't find where to run the trace to complete the circuit.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
its will go to both sides of that pad then
Indice 3
5 commentaires:
After further review I had told you the wrong pin it is actually number 17 the one to the direct left of the one pictured..I'm sorry for the mix up. If I'm thinking correctly it goes to the point above it but I still have no clue.
par
Thank you so much the amount of research I done turned up nothing but this is gold...I do have one other follow up question I'm sure ik the answer already but I just wanna make sure that pin 19 connects to the one right above it? And pin 14 goes down to that diode or fuse? I'm not entirely sure I'm learning as I go lol
par
@deathray01 yes thats right, you just follow the traces coming from the pad
par
I'm sorry I keep asking questions but pin 14 does it matter if its connected to the diode or does it need to touch it I seen on some videos where they soldered it directly to that diode but never showed if they actually fixed it and I was curious if that was the correct way I'm sure it is being that there were a few who done it.
par
@deathray01 they probably done that just to save them scraping the trace down to the copper so you can solder to the trace or diode it doesnt really matter
par
Ajouter une réponse
Evan Wise sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 189
