Aller au contenu principal
Informations de réparation et de démontage pour l'iPhone SE de deuxième génération, annoncé et mis sur le marché en avril 2020.
20 questions Voir tout
Where is this part's location? NFC(?)
Hi professionals!
Please help me: where is this little part's location.
It may have to do with the NFC..
I replaced the housing with everything, and I simply don't know where this part was to be put.
It seems important because NFC is not working...
Thank you so much for your help!
And the answer:
Thank you @hellomacos !
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Thank you so much for the fast answer.
Unfortunately, this is not the metal part of the antenna (step 29) that fixes it to the housing 😟
I double - checked, just to make sure...
Based on the searches element's look it must connect some circuit... but I leave it up to you, because I have no idea, where it is from 😟
[image|2732260]
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi
It looks to be some form of grounding point/shield/tab
Heres what we can try to help find where it came from
Go to step 29 of this guide Remplacement de la carte mère de l'iPhone SE 2020
Is this metal piece from the piece removed on step 29?
Also is it from the sides of the Taptic Engine?
If you look at the last step of this guide you can check
Remplacement du Taptic Engine de l'iPhone SE 2020
If so please let me know if it is or isn’t as if it isn’t we can keep looking:-)
Hopefully this helps
Any questions please ask
Image iPhone SE 2020 Carte mère
Tutoriel
Difficulté :
Modérée
45 minutes - 2 hours
Image iPhone SE 2020 Taptic Engine
Tutoriel
Difficulté :
Modérée
40 minutes - 1 hour
Indice 2
6 commentaires:
(I have added an additional picture to the question... perhaps it helps...)
par
@airwinpara
Let’s keep looking:-)
Look at the last step of this guide
Does your part look like any of the pieces/arms of the Taptic Engine?
par
Thank you again!
Checked- unfortunately not😕
I alao taught that the ones on the charging connector aides might look alike- but those were not the one neither...
My point in finding the location was because I was thinking that this is missing from the NFC part.
So to turn it around: if you still have the patience: is the NFC responsible a tenna part the top left antennas in the black unit, or is to be searched here at the bottom, near the heptic part, at the wifi antenna?
If the two are related (nfc not working and the little part) I might be closer to the solution.
Thanks again for helping me in this one 🤘
par
@airwinpara
Your most welcome
I will help you get your device sorted
I have unlimited patience 😎
My goal is to help you:-)
I Believe the NFC is part of the wireless charging coil
And if you look at this link
https://www.ebay.co.uk/itm/192640969634?...
There doesn’t appear to be that little piece of metal
Was the wireless charging coil damaged at all? Or was it preinstalled
Also did you use a video,guide or you own Knowledge to fix the iPhone?
par
@hellomacos
Your help is much appreciated :)
My apologiez - yesterday I was wrong: the small piece I was loooking for the location of, was indeed on the leg of the taptic engine (the one by the edge) - I did not realize, because it looked perfectly ok without :)
So thank you so much for helping me solve this one.
NFC: Interesting - never taught of the NFC being part of the charging coil - it makes sense... And indeed, no little piece of metal there
I had to change the full housing (phone fell from 5th floor :o ), and had to remove the back cover - coil is glued to the middle part, and the housing did not have it pre-installed, so the damage can not be excluded.
For chanrging purposes, the coil is working as it should, only the NFC is non operational...- I must have damaged something...
For the repair, I used video guide from ifixit (obviously) ;) and I also have some knowledge with smartphones, from the past.
Thank you so much for your impecable support and help!
Ervin
par
Afficher 1 commentaire en plus
Ajouter une réponse
Ervin Szabo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 25
Total : 749
