Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460). Released May 2021.
top volume button isn't working
the top volume button is stuck. is there any way to fix that?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
Indice 1
1 commentaire:
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
par
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
Indice 0
1 commentaire:
Thank you - will try that.
par
my power button is not working well, it is mostly stuck. Can this be fixed?
Indice 0
Ajouter une réponse
Pam sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 35
Total : 523
