Is there a tutorial for the logic board replacement?
Is there a guide out there on how to replace the logic board?
iMac Intel 27" EMC 2429 Motherboard Replacement
This is the closest I can find. This guide is still in progress, so be careful.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 43
@civil35 this guide IMac Disassembly should work for you. To remove the logic board you do not have to follow all the steps just remove:
• Glass panel
• LCD panel
• Power supply
• AirPort card
• Backlight pressure wall
• Optical drive
• Optical fan
• IR board
• Memory
Note: The SSD-only CTO option has a hard drive power plug, on the back of the logic board. It shorts out the HDD power when no HDD is present. Transfer this plug (922-9877) if replacing the logic board.
This is a comment only since the snippet of the disassembly needs to be verified by you. Let us know if this worked for you .
par oldturkey03
