Aller au contenu principal
First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
Questions au sujet de 94 Voir tout
Question close
3G not working (SIM detected, no signal)
Hi, I bought a used iPad but the previous owner said the 3G module isn't working. So I thought: I'll do a hardware reset and then it will work.
But no, after inserting a SIM-card, the iPad is searching for the 3G network but with no result. So it's no hardware problem (I think).
What could be the problem and how can it be solved?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 solutions
Hey,
My experience with iPads is not all that... however in my opinion it could be:
The aerial has come undone, it is just like wireless aerials in laptops etc so would be an easy fix once you get the screen off.
It could be the 3G module itself, this is a separate part which attaches to the logic board and where the aerials both attach.
If you're going to disassemble, follow the guide on here:
iPad 3G Communications Board Replacement
the easiest way to open it is as shown on the above link, start on the side where the volume control and sound toggle switch is as this should reduce the amount of clips that get broken :)
hope you get it fixed!
Cette réponse a-t-elle été utile ?
Indice 0
hi there,
I notice you said you have done a hardware reset, I'm assuming you mean when you hold the sleep button & home button so it reboots.
If not try this now. then try connecting to a wifi network. I would speculate that the time on the i device would be incorrect. I think you will find this to fix your problem.
thanks
Aaron
(atmtech72)
Indice 0
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 7,667
