Aller au contenu principal
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
Questions au sujet de 106 Voir tout
iPod nano 7th generation battery percentage glitches when dying
it will go from 5% to 25% for a few minutes and then back to 5%. does someone know what could the problem be?
(it doesn't stay at 5% or 25% all of the time just using those numbers as examples)
i just noticed it only glitches after saying connect to power and goes to 20-30% for 30 secs-1 minute
i have had problems with this same device before.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi
When battery’s start acting like this they usually need replacing
Battery’s degrade with age ,things like heat can also play a part in it too
In order to replace your iPods battery you will need some quality soldering tools such as
Soldering iron ,solder wire ,solder wick and flux
You will also need to follow along with this video (linked below)
https://m.youtube.com/watch?v=U_N55_Tdz2...
If you need any help with it please let me know
Hopefully this helps
Any questions please ask
Indice 3
2 commentaires:
well, this is the heating vent ipod which you have dealt with before, so im sure its the heat thing again .-.
par
@timtomissus
Heat can play a part in it but these devices are at the age now where their battery are going unfortunately;-{
par
@hellomacos has the repair covered; I just wanted to add my support to his diagnosis.
The thing is, there are only two parts involved in the battery data; the battery itself and the logic board. Assuming you've tried the software solutions like restoring the phone back to the defaults and updating the OS, if it is indeed a hardware issue then it can only be solved by replacing one of those two parts. Since batteries are inexpensive, it would make sense to try a new one as the first step in trying to fix your iPod.
If the battery doesn't resolve the problem, then it's most likely got to do with the logic board, which is generally not repairable by us home diy-ers. So yeah, your best bet at this point is to try a new battery.
Indice 3
2 commentaires:
Ajouter une réponse
timtom7777 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 8
Total : 107
