Aller au contenu principal
Modèles A1297 Unibody : Début 2009, Mi-2009, Mi-2010 & Fin 2011
544 questions Voir tout
Logic Board (bare) won't power on - final checks?
I've got an A1297 which won't power on. I've tried a bunch of the usual troubleshooting steps, and have ended up failing to get even the bare logic board to power up.
The Magsafe light shines green, and I can see 19.3V and 16.5V at the logic board dc inlet (grey pair to black pair, and black single to black pair respectively). I can also see 3.3V across the power switch pads.
I've tried the "no battery boot" procedure (unplug everything, short the power pads for 10-30sec, plug in Magsafe, continue to short for 10 sec, open the power pad circuit, then close it again briefly to boot).
I tried a gentle reflow in my kitchen oven (10 min at 200°C), and that hasn't changed anything.
Are there any other diagnostic steps etc. I could take to determine what might have failed? The machine just stopped working one day - no liquid ingress or shock.
Thanks in advance!
Répondre à cette question J'ai le même problème
Indice 0
7 commentaires
I also have a bare logic board that will not power up with the charger. I only have a fan plugged in and it does not spin. It does, however, boot if I connect the battery AND charger. Do we expect that it should automatically boot up when the charger is connected? I’m trying to figure out if this is a symptom of my main problem or normal behavior.
par
@moley check your board. What is the 820-XXXX number on it.
par
@lzrBeamer is this for the same computer as questioned by the OP? What are you checking for on your board?
par
@oldturkey03 A different board (mid 2012, 15” retina) but my question is more general about booting up without a battery since OP discussed “no battery boot” procedure. Should the board boot and give fan spin by simply plugging in the charger?
par
@lzrBeamer it is supposed to come on when you connect the charger. However, you most likely also have power on pads on your board.
par
Voir 2 commentaires en plus
Ajouter un commentaire
1 Réponse
Réponse la plus utile
you need to check the power rails to see whats missing, you will need a brd file and schematic so you can locate them.
Indice 4
1 commentaire:
Thanks, will do. I'll report back if I find anything.
par
Ajouter une réponse
Scott sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 58
