No battery detected after battery change
Hello. I have MacBook Pro, a 1398 15” Late 2013.
Actually I had no problems until I changed the battery. I changed the battery and ran it, I used it until it had 5% charge left and then I plugged it into the charger.
But, the next day when I turned on the computer, I got the error message that no battery was detected. I tried many things (PRAM & SMC). but the problem is that although it does not recognize the battery, it works with the battery and when I plug in the charging cable, the cable LED does not light up. there is also an excessive fan noise when running on battery and the fan never turns off. When I do SMC reset again, it does not see the battery again, but the cable LED lights Red and the computer shuts down when pulled.
2 commentaires
Sorry you got a bad battery😫
You’ll need to contact the seller to get a replacement.
The problem is the batteries micro-controller failed. This has been a large problem across many as the chip supply has been a problem.
par Dan
@danj thank you for your help.
par barbaros
