Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair information for Sharp televisions.
80” Sharp LC 80LE650U has error code 1 slow blink and 1 fast blink
My Sharp TV won’t turn on..have tried the reset sequences to try to get to the service screen to reset the Backlight error. I replaced the backlights and now I have two slow blinks and 5 fast blinks. What else could be the issue? Power supply? T-con board? Main board?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
10 commentaires
@dolaugh so right now, your TV does not turn on. Correct? All you get is the blink code but it does not turn on.
par
That’s correct..it went from one slow and one fast error code to 2 slow and 5 fast blinks now
par
I did replace the backlights..it was a chore on an 80” screen. That is when the error codes went from 1 fast and 1 slow to two slow and 5 fast blinks
par
I disconnected the ribbons on the t-com and the backlights did not come on nor did the tv..I’m back to one slow and one fast blink
par
I did the reset sequence..the backlights turned on with the t-com ribbons disconnected…so it seems it is the t-com that needs to be replaced
par
Voir 5 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
The 2-5 blink code can be a bad T-con board or even a panel issue. Try disconnecting the ribbon cables between the T-Con and the panel. If the TV then powers on, the panel has failed. If the TV still has the 2-5 code, I would change the T-Con board. Do you have a multimeter? Post some good pictures of all of your boards after you remove the back cover. Post those pictures with your QUESTION. Ajout d'images à une question existante
Update (11/17/2022)
@dolaugh this shows how to measure the voltage
Indice 2
6 commentaires:
Hey @oldturkey03 ..look at my last photo added and let me know what you think is the problem ..finally got the TV picture to show up..but it has lines all over it.
par
@dolaugh your TV has a broken LCD. Can’t fix that. It’ll need a replacement display which will be hard to come by.
par
I bet my shirt it got busted with the big suckers that shopjimmy sells with their LED bars. Tools designed for windows, not screens. We can clearly see the circle of the suction cup that broke it...
par
Code 2 slow et 3 rapide ??? Je fais quoi?
par
@carolelavoie 2 slow 3 fast blinks code means:
"Power supply error 2 (*2) D+3.3V error" The 3.3V should come from the main board. There are no schematics that I know off for the model listed. You may need to consider a new board :( Is your TV a Sharp LC 80LE650U?
Translation
@carolelavoie Le code 2 clignotements lents puis 3 clignotements rapides veut dire :
« Erreur d'alimentation 2 (*2) Erreur D+3,3 V ». Le 3,3 V devrait venir de la carte mère.
Je ne connais pas de schémas pour le modèle que tu as mentionné. Tu devras peut-être envisager de changer la carte :( Est-ce que ton téléviseur est un Sharp LC 80LE650U ?
par
Afficher 1 commentaire en plus
Ajouter une réponse
Ron B sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 35
Total : 2,174
