chantell it should work like this:
"- Open i-tunes on your computer that you sync it to
- Plug in your phone to the computer
- open "Address book" window's address book program. Its under start-programs-accessories
- Back to iTunes, click on the phone icon on the left
- Click on the Info, and under "Contacts" (the first one) check "sync contacts from" and then pick "Windows address book" from the drop down menu
- Click all contacts
- Then at the bottom right of iTunes, click "Sync" When asked to Merge or Replace. Make sure you select MERGE or it will delete your contacts on the phone."
Once you do your repair, a restore should replace that info from the computer. Just make sure you keep the same computer to sync, and do not sync another iPhone/iPod on it. It might just erase the info :-) Hope this helps, good luck.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
