Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Xiaomi Redmi Note 6 Pro est un smartphone milieu de gamme de Xiaomi, sorti en octobre 2018. Il est équipé d'un écran LCD IPS de 6,62 pouces, d'un capteur photographique principal de 12 Mpx, d'une batterie de 4000 mAh, d'un lecteur d'empreintes digitales monté à l'arrière, et fonctionne sous Snapdragon 636.
Just changed battery, still doesn't turn on.
Like a year ago had a Redmi 6 pro, worked fine and suddenly didn't turn on stuck at the android logo.. then nothing. Now i just replaced the battery which was so weird, so "fat" it pushed the back cover out. And now I'm trying to charge it and nothing happens, what else can I do?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
3 commentaires
@albdumb, A swollen battery is a big fire hazard and the battery must be handled with care, and disposed off according to local regulations.
Did you get a new battery from a reputable vendor, or just randomly online? New batteries can be faulty, but we would have to know more.
par Partager
Yes I bought an original "factory battery" from a trusted place. bN 47
par Partager
No actually BN 48 sorry
par Partager
Ajouter un commentaire
1 Réponse
Solution retenue
You said it was stuck at android screen, that sound a lot like a boot loop. Sadly there are multiple reasons for a cellphone to do a bootloop, the easiest repair you can do is to unplug components one by one and seeing if the phone fully starts.
When your phone boots up, it check every component (camera, microphone, speakers, etc..) if they are there or not. If one of your components is damaged it sometimes wont be able to tell if its actually there or not and will reboot and check again. I would recommend disconnecting a component, try to start the phone and if it loops, you reconnect that component and do another. It's not a perfect method but it will tell you if there is something else than the battery that needs repair. Of course remember to always disconnect the battery first.
Indice 1
1 commentaire:
As I charged it for a longer time I felt the battery was warm, so I suppose something else is wrong. The old swollen battery didn't show sign of leaking. The phone never was dropped, it still look like brand new so I'm a bit mad. All I can remember the storage was always on edge to full, I guess I take it to a professional. Thanks anyway.
par Partager
Ajouter une réponse
Albertina Dumbstein sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 1,283
