Is it possible to fix a popped out swivel hinge of Sony wh-1000xm5?
Is it possible to fix a popped out swivel hinge on my sony XM5? I was wearing them and accidentally hit a pole. The swivel hinge on my right earcup cam out :(
Any recommendation or teardown fixes for it? I tried to push it back in, but i cant be fully inserted.
9 commentaires
@xhnnkoh11 can you post some pictures of the swivel and where it came out of etc. with your QUESTION? That way we can see what you see. Edit your QUESTION and use this guide Ajout d'images à une question existante
par oldturkey03
Hi, Thanks for sending the guide, it was very helpful
par Wai Xhnn
This happened to mine a few days ago. Were you able to fix it?
par Manuel Del Rio
How can I fix this myself? Sony repair is asking for too much momey
par [deleted]
I had the same issue with mine, Sony is unwilling to repair under warranty and the cost is high to repair, does anyone know how to “pop” the swivel back in, if no one else knows how to do so then I might as well try myself. Because the internal side of the swivel is metal and the outside is plastic, I would assume heating the plastic and maybe cooling the metal would work, as well as adding some silicone or other adhesive to hold it in place.
par Liam Nosbach
Voir 4 commentaires en plus
