Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Xiaomi Redmi Note 9 est un smartphone de milieu de gamme de Xiaomi, sorti en avril 2020. Il dispose d’un écran LCD IPS de 6,53 pouces, d’une caméra arrière principale de 48 MP, d’un capteur d’empreintes digitales situé au dos, d’une batterie de 5020 mAh et fonctionne sous MediaTek Helio G85.
Phone drop in water
Yesterday my phone drop in water it was working fine but the flashlight was on and not turning off so i power off the phone but flashlight is still on and not turning off and now my phone is not turning on but flashlight is on
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Phone drop water not on my phone
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
saleemkhanx001, The first thing to do now, is to stop trying to turn it on and DO NOT connect a charger.
You’ll have to open uptempo phone and remove the parts on the inside, for best results. Inspect the boards closely for corrosion and damage, you’ll need good lighting and possibly a magnifying glass. Use some distilled water and gently use a brush (fex a toothbrush) and clean the boards and case. Apply gentle pressure, but do not overdo it.
Once you gone over it with distilled water, do the same thing with >99% isopropyl alcohol. The IPA displaces the water, and IPA evaporates in seconds to a couple of minutes. Once you’ve cleaned everything with IPA and have let it dry off, make sure once more that there is no damage or corrosion present on the boards.
Connect the screen and battery again and check if it will boot. I prefer to test the devices for 100% functionality before I close it back up. If you’re lucky and there hasn’t been any bad damage, your phone should start again, but remember: even one single drop of water in the wrong place can be truly destructive for a phone!
Indice 2
My phone had repaired but still facing problems related touch not working properly and front camera, rear flas light not working
Indice 0
Ajouter une réponse
saleemkhanx001 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 564
